holmessquad
Pros....Cons.....which kit is the best to level the front of my PW with the rear?
Sent from my SM-N950U using Tapatalk
I just bought a 2018 PW and I'm planning to level it out. I'd like to go with Thuren springs and shocks for the front. Should I get longer sway bar end links too? or, are the OEM end links ok to use with a 2" level kit?
thanks guys
Do you lose towing capacity with the Thuren kit?
A smidge, but hardly noticeable.
Theres a guy on pwr who actually has comparison numbers of the difference. It was very minor. Slight more sag, but nothing to write home about.
I just checked the Thuren website and it says the sag will be similar to a 1500. That I cant have, already getting rid of my 2017 1500 for a Powerwagon.
The included rear coils springs are quite a bit softer than stock. The ride quality and suspension travel benefit also comes with the drawback of more sag when weight is in the bed, or vertical on the hitch. The rear suspension with our coils will sag with weight similar to a 1/2 ton truck. (Quote from Thurens.)
Nope, the stock front units are fine.
