Leveling kit
bigbillg
I want to put a leveling kit on my gen 4 ram I don't know what I should get a 2" or 2.5"
brasso
2012 ram 1500 4x4
Get the bilstein 5100 shocks and set them to 2.8. You don't sacrifice ride quality that way and it is better for your front end
B
bigbillg
These shocks will level out my truck
Cruizer
Ohio
2010 Sport 4x4 QC
It depends on the rake your truck currently has. Some people go with the 2.1" setting, some go with the 2.8" setting. Best thing to do is measure the top of the wheel well on each corner and see how much rake your truck has before starting. That will tell you what setting you will want to run and ensure you don't go to far if your rake in minimal. That would cause your truck to go nose high.
DannyMK2
Long Island, NY
2015 Power Wagon
I just want it to look even front and rear
2" leveling kit will make the truck look even. 2.5" leveling kit will make the truck measure even height. i have a 2.25"...i think it still looks a little nose high, even though its really .25" lower then the back.
h2oman
SoCal
Every truck will be different. Mine are at 2.8 and I have 1 inch of rake.
dirtridersr
I have a 2.5 in level and I still have 1.25in of rake :(
2014StormTrooper
Aggieland, TX
2014 Ram 2500 Longhorn 4x4 2003 LY Evo VIII ER Built 2.2L
6.7 CTD / 4G63
i have a 2wd and can't find a good leveling kit :(
RyanJM
Houston
2014 Express RC Black Edition
+1 I measured my 13 to see how much rake it had and how much I wanted to keep for loading the bed and towing without having it nose high. I would measure it and depending on what you do with your truck go from there. 2" worked for me with just over 1" of rake. No vibration in any 4wd setting. I would have done the bilsteins at 2.1 if I did it again but the spacer were thrown in as part of the deal when I bought the truck.
B
bigbillg
Well I went with the 2.5 kit I didn't think it would make a big difference in the look of it but it did and I'm happy with it and it only took about a 1 hour and a half to do
viper919
I got the 2in on mine...its close to being level and even though its only .5 inch it's just a little easier on the front end....or at least thats what I tell myself
Ricky91
