Lift help
Littlec0023
Hami 5.7
I have a 6in rc lift on my 14 ram 1500 I wanna get rid of the coil spacer on rear and but just a 5in coil on read does anybody know wear I can buy just the coils I wanna get a little more lift out of my truck so wanna replace it with those then add a 2in top gun spacer to it also where to buy just the spacer for front so I can put on the bilsteins, or who makes a 3in body lift for my year any help would be great thanks
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
Should be able to order the 5" coil from zone suspension
L
Littlec0023
Hami 5.7
Yeah I just called they said not a good idea what I’m trying to do will eat half shafts every couple months but I’ve seen others on here do the same
JB1
Houston, Texas
You can’t eliminate the rear spacers because IIRC they do other functions too, kinda like a combo bracket. However you should be able to add a taller rear spring like ICON 1.5” coil and swap in place of your stock rear coils.
If you already have spacers on top of your front coils then no you can’t add another and stack them. You may be able to add Bilstein struts with your top RC spacer only, I believe other RC owners have done that. Other choice would be to buy the RC 6” lifted struts and add a small 2” spacer on top of that
Post some pics of your setup front/rear
L
Littlec0023
Hami 5.7
That’s what I have is the rc lifted struts
5.7L
Hey Littlec0023, have you went ahead and changed this yet? Im interested in doing the same with my rears. Looking to switch from a block to a 5" coil
