Lift tire question ?2016 3500
spence36
Cummings 6.7
Anyone know what is the largest tire I can
Put on stock 18" wheels with a leveling kit ? The truck shop wants me to put 35x12.50 and new rims but I dunno if I want that I want a larger tire for my adventure but was think a bit smaller maybe 33x10.50 but not sure if it will look right , and keep my stock rims anyone have a suggestion on good tire size ? They also said I can't go wider with the stock rims is the other reason why
Ram-engineer
hemi 6.4
Ill be going with 35x12.50 on 18s
Sent from my SM-N930V using Tapatalk
MADDOG
Living in a Firepit
6.4L HEMI
Your stock wheel is an 8" wide wheel I believe so a 35x12.50 might be a bit too wide.
S
spence36
Cummings 6.7
Thanks Guys !! I stopped in my lift shop and he explained I could use the stock wheel but run the risk of rubbing because the wheel doesn't have enough offset so I'll be getting wheels also 35x12.50 will fit easily if not I could go with next size down like a 315 so feel better now I was worried also in case I have to chain up about clearance issues so I have to go with the more offset wheel to clear inside with chains due to the larger tires . anyone wanna buy my ram aluminum alloy wheels and tires only about 1000 miles on them brand new no scratches etc ...... firestone HT tires also 1k miles brand new !!!
