Lifted 2wd 4th Gen Pics- Lets see them
Mattyyo
Houston
4" lift , 35x12.5 toyo mt , 20x10 fuel assault rims
2014RAM5.7
Ontario, California
So my first attempt at installing my coil spacers was a failure. Didn't think about it at the time but I should have put the coil compressors on before lowering the lower control arm instead of after lowering the arm. Took me a while to realize where I went wrong. My buddy needed his compressors back to help out one of his friends. Due to the lack of space on the 2wd trucks, should I use an inside the coil compressor? Also, any recommendations? I want to have this done in the next few weeks. Need to buy a new jack, too. Thanks.
GoatRider
Eunice, Louisiana
V8 4.7
Wow, that was original. Never heard that one before. haha
They say it takes a long time to get to England in a rowboat, or a jet-ski, but have you ever seen girls frowning on a jet-ski?
2013 Ram
4.7L v8
K&N filter
Flowmaster 40
IG- the_sneauxman
GoatRider
Eunice, Louisiana
V8 4.7
Pushed the wrong quote button. Kindly ignore me until I learn how to forum.
2013 Ram
4.7L v8
K&N filter
Flowmaster 40
IG- the_sneauxman
2014RAM5.7
Ontario, California
Finally get to contribute to this thread...
2" Daystar Coil Spacer
33x12.5x17 Atturo Trail Blade MT
17x9 -12mm Raceline Defender Wheels, Satin Black
Still have a drop in the back, not coming out anytime soon.
No rubbing but I feel like I will need new arms after some time. They do sometimes hit the coil pocket going over tall speed bumps and longer sway bar end links I'm sure will help. I'm happy so far.
co-pilot
houston,tx
I was gonna do research on lifting a 2wd......and found this?????
Can't believe the mods let this garbage go for so long.....
65 pgs.....wasted time......
Statcher1
Kentucky
And what might the garbage be? I see lifted 2wd trucks in this thread. There’s your proof and info for you. With a few casual conversations in the mix. Calm yourself
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Casual conversations? The thread is about pics and specs not about bs sidebar with intentional insults towards the 2wd group.
Anyways, I too came to this thread because I am about to lift my 2wd as well and this thread really disappointed.
co-pilot
houston,tx
Are you serious?....... & why tell me to calm down? .....i only made a true statement?
Guess some people just like to argue more than give helpful information
2018 2wd
2015 Ignition Orange
7" MaxTrac front lift (4.5" spindles and 2.5" springs) with Mevotech control arms
4.5" MaxTrac rear lift (3" springs and 1.5" blocks) with Spohn control arms
Wheels are Konig LocknLoad 20x8.5 with the stock tires for now.
You used 3" springs in the front instead of the 2.5" that came with the Maxtrac? And if you did where and which ones did you get ? I am looking for 3" springs for the front myself ... thank you in advance
2018 2wd
14 Ram Lonestar 2WD
4.5" Maxtrac Spindles
2" Front Spacer
3" Rear Coil
3" Body Lift
22x12.5 Ballistic Rims -44
35" Nitto Trail Grapplers
Slimer Green Autoflex
View attachment 196841 View attachment 196842 View attachment 196843 View attachment 196845 View attachment 196846
How long have you had that 2" front spacer and which one did you get ... are you without concerns about that set up in the front? I am planning on adding a 1" or 2" inch spacer in the front and another spacer in the back to level it out .... right now I have the 7" maxtrac just the way it came out of the box but would like a little more in the front to avoid rubbing when full lock or backing into a drive way ..
Any info and links to what you have would be greatly appreciated ....
Litos
Houston
HEMI 5.7
Not exactly sure which spacer it is, but any 2" spacer will do the trick...spacer has been on for a hair over 2.5 years...
also, if you want to get more lift, I would highly recommend the 3" body lift and have someone tac weld it in place...
gotta trust someone to do it on their free time though (buddy, of someone else)
I actually want a 5" Rear Coil, because you can see the squat from "most" angles...
like these lol
B34E5FAC-4E2F-4FEE-BA20-C7E0EF94BA4A.jpeg D1376845-CA64-4F23-8EAA-B0576585B215.jpeg 6113484F-24B0-4055-81DC-642AC683BEB5.jpeg C2D84BC1-4817-4623-90C8-F4E2A2C80760.jpeg
Joey93
