Lifted 2wd shock help
BenzHEMI
I installed a 3" spacer lift on my 1500 2wd. My problem is shocks. I have read numerous posts and couldnt find a solid answer. Can i use 2500 shocks? and what is the difference between 2wd and 4wd shocks. Thanks
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
In the front find shocks for a leveled 4wd ram of the same yr. I went through this with my dads truck. And the same goes for the rear if you add a block.
Sent from my VS920 4G
B
BenzHEMI
So i can get the 4wd shocks that say 0-4 lift? For 1500 or 2500
