Lift'EmHigh
I bought my truck lifted 9 inches. 6 inch suspension lift and 3 inch body lift.
I realized when I replaced my u-joint on my rear dif that my rear drive shaft is too short bc of the lift. Its about 3 inches too short and I have to pull it away from the transfer case to get it to reach the rear dif.
I want to get a driveshaft from a junk yard and have it cut and welded.
What length would I need(if you have had this problem)?
If you havnt but know what the stock length is that would help too.
