location of starter relay on '08 5.7
racejunky
northeast florida
'94 & '96
where is this thing at? I have been told it mounts behind the fuse panel under the hood but when I removed the panel box there is nothing there. Found out why there is no starter relay to be found. It seems that in a blinding flash of brilliance Dodge decided to integrate certain components thus removing the $15.00 relay so that we would have to part with a paltry $3- 400.00 for a complete tipm unit to fix an ailing starter relay. I see where there is a way to bypass a fuel pump relay so I was wondering if maybe the same thing could be done with the starter relay but that doesn't seem to exist. If there is some way to make this happen, please inform me of what would have to be done to make this issue go away. there are plenty of relays to be had so if I could find out what the wiring for this is maybe I could splice one of those in. Maybe?
R
racejunky
northeast florida
'94 & '96
I understand they make a fuel pump relay that can bypass the tipm and can be had fairly reasonably on ebay among other places. If that is the case why can't a starter relay be wired in to bypass the tipm? If a universal type relay will work for this all that is needed is to know which wires to splice. not having a wiring diagram that tells me this I am at a loss to attempt such an undertaking. If anyone has such an animal or knows where I can acquire this info I would be very thankful for that info. My manual only gives me typical from 2002
Chahta
Tennessee
Has this been answered anywhere? Youtube videos seem to address 2009 and up but not 2008 and below.
jws123
nj
That is because tipm failure is not as common in older rams normally its something else but yes when they fail most of the time it can be bypassed you just need a good wire diagram.
Chahta
Tennessee
I am trying to check the output of the relay. Do you have a wiring diagram or wire color going to the fuel pump? Thanks.
Gendeu1
