Install Relay Bypass for Blower Motor
DeputyChef22
Arkansas
Below is the step by step as provided by AI. I’m pretty handy and can follow most of this but steps 3&4 get me confused. Please help.
You will need:
• 40A automotive relay (4-pin)
• Inline fuse holder (30–40A)
• 10–12 gauge wire
• 16–18 gauge wire (for trigger)
• Ring terminals
• Heat shrink
That’s it.
The Relay Has 4 Pins
They are labeled:
• 30
• 87
• 85
• 86
Think of them like this:
30 = Power IN
87 = Power OUT to blower
85/86 = Small trigger wires
Step-by-Step (No Shortcuts)
1️⃣ Disconnect battery first.
Always.
2️⃣ Run NEW power
• From battery positive
• Through your new inline fuse (within 6–8 inches of battery)
• To relay pin 30
That wire should be 10–12 gauge.
3️⃣ Connect relay output
• Relay pin 87
• Goes directly to the blower motor power wire (cut and isolate the old TIPM high-current feed)
You will cut the blower power wire near the TIPM harness.
The side going TO the blower gets connected to relay pin 87.
The old TIPM high-current side gets taped and sealed — no longer used for power.
4️⃣ Trigger wire (this is the safe part)
Now take the old TIPM blower feed wire — the one that used to carry high current.
Instead of powering the blower directly, it now goes to relay pin 85.
That wire now only carries about 0.15 amps.
Zero heat issue.
5️⃣ Ground the relay
Pin 86 → good chassis ground.
Done.
What happens after this
When you turn blower on:
TIPM sends small signal → energizes relay → relay closes → battery sends clean power to blower.
TIPM never sees heavy load again.
Burned cavity becomes irrelevant.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You will need:
• 10–12 gauge wire
• Ring terminals
• Heat shrink
That’s it.
They are labeled:
• 30
• 87
• 85
• 86
30 = Power IN
Always.
2️⃣ Run NEW power
• To relay pin 30
• Relay pin 87
Zero heat issue.
Done.
What are you trying to accomplish?
DeputyChef22
DeputyChef22
Arkansas
Bypass the overheated part of the TIPM where a fault blower motor charred a fuse and ultimately melted the wiring plug to where it won’t sit flush (supposedly for long).
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
(Don't trust Ai with this)
Is the terminal damaged or the connector housing?
If the heat damaged the terminal, how about a repair pigtail to splice in and fix it?
You should be able to pick up a whole connector pigtail from a any 13-18 truck at a salvage yard, green C7 connectors (7287-8884-60) will be the same but may use different pin locations based on trim/features.
If you want to buy the connector housing and transfer over the existing wiring one at a time (de-pin/re-pin), here's the part number and a link ...
Mouser Link
7287-8884-60 (C7 Green)
( I'm shocked to see 89 in stock, $8ea)
If you state your truck year, model (ie 1500) and trim, I can get you a connector pinout as well for this.
If you just need a single pigtail for that terminal let me know/Message me for details)
Mike G.
M2 Mods
www.M2Mods4Ram.com
M2 Mods at Ramforum
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Mouser Link
Mike G.
M2 Mods
www.M2Mods4Ram.com
M2 Mods at Ramforum
This, AI will give you an authoritative answer with a response conflated by multiple online posts discussing a topic (not necessarily your topic). It's best used to guide your search to someone like @Mpgrimm2 and not follow it's instructions step by step.
juvaknight
Miami, Florida
Well, it worked for me got the A/C blower working again I only changed the trigger wire that part of the instructions was confusing
1walker
mi.
morning all....i need a pikture of the relay bypass for the blower mtr. what wire gets kut thanks....
APlosser
Tulsa, OK
Could you provide a pic of your bypass? Also, What exact trigger wire did you end up using to activate the relay?
Loganlucky
MB
Following as I’m having this issue as well, and looking to clarify. C7 pin 21 wire under pdc, melted housing around dark blue wire. This 12g wire is the blower motor supply wire, which will now be connected to 87 on the relay. But which pin/wire is the trigger wire that goes to 85 on the relay? If I’m understanding correctly is it the old pin 21 wire, to 85?
DITRIO
