Long tube headers
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Hey I've being trying to do my search on some header for my 2014 2500 5.7 header but haven't found hardly anything. The exhaust shop that install my Y pipe said that he can't do it, so do anybody have any info on doing long tube?
Ratket
Arizona-
it's on here- I have seen it a thousand times- just never payed attention - someone will chime in.
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
The guy at the shop said that it might throw a code so I might not want to do it but somebody on here that have done it and what where the outcome.
dearchristopher
Galveston, TX
from what I've heard, shorties are more beneficial with the 8 speed trans. easier swap on you as well
Sent from my LG-D850 using Tapatalk
Talon_66
Deadmonton
American Racing Headers and Stainless Works both have headers that will work on the 8spd.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
ARH is the only company that makes longtubes for the newer 2500's. They use Green cats that shouldn't throw a code, but most guys will get a random code that pops up every 6 months or so. With custom tuning, Hemifever can disable the code so that you never get a check engine light, with or without cats.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Longtubes will always outperform shorties on these motors. The 2 fastest 8 speed trucks are both running ARH longtubes. 1 ran a 12.70 N/A and the other ran a 12.56 N/A.
theviking
I have the catted ARH long tubes on my 2015 2500 w the 6.4, purchased from Moe's. They fit very well, comes with y-pipe, and the install isn't too bad; although they don't provide much in the way of install instructions. I didn't get any codes until I installed the Magnaflow cat-back as well. Then I threw codes periodically although not recently so not sure if the computer has adapted somehow. Diablosport is still dragging their feet on the 2015 6.4 tuning so can't turn off the codes or do any custom programming. Still the truck definitely picked up a bit in the mid range and upper end. Hoping a custom Hemifever tune will eventually take full advantage of the headers.
If you leave the stock muffler & cat back the truck will sound almost no different than stock. Perhaps just a little bit more mechanical noise coming through the exhaust. With the Magnaflow 19200 kit it's much more aggressive. Although I'd like it to be a bit quieter now everyone who hears it says it sounds great.
theviking
Some pictures of the AHR 2500 headers installed on my truck. These will work on both the 6.4 and 5.7 motors apparently. Too bad they're hidden from view as they are a work of art. And cost about as much:)
Hemifatboy
Redneck Rivera
6.4 hemi
Nice set up , is that the 4" magnaflow cat back?, I have been looking at a new flowmaster 3.5 in and out muffler , part number 853848 , started a thread for it
theviking
Yes, that is the Magnaflow 19200 cat back kit. Not sure it made the truck much faster but looks sooo much better without the stupid resonator.
Hemifatboy
Redneck Rivera
6.4 hemi
Yeah that resonator looks crapy In the wheel well , what were they thinking
theviking
Was always curious how one of the more mellow Flowmasters would sound. They list two 18" mufflers "Specifically designed for Dodge trucks with Hemi engines", 853558, 953558 (stainless or aluminized). They also have a 22" version in the 50 series (53550, 53553) as well as the Hushpower line in a number of lengths and inlet/outlet sizes. And then there's the full cat-back kit.
Flowmaster 817709, Flowmaster American Thunder Exhaust Systems - Truck/SUV | Flowmaster
Hemifatboy
Redneck Rivera
6.4 hemi
Crap they have too many mufflers , I put the wrong part number down it should be 853548
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
You might need a tuner with a custom tune to turn off the codes. Contact Matt from moes. He has a ton of knowledge and should be able to help you.
I have sent him two pm but no answer yet.
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
I do have the Y pipe and a 22' or 24' Magnaflow muffler now, man those ARH header do cost some money but I will like to just up the ponies and if I don't get better mileage that's okay but for sure more hp. I think that I need to go to another exhaust shop to see if they will install some longtube.
drbsteck
Random question if someone might know....
Can you put a set of ARH long tube headers made for the 8 spd transmission on a 2011 1500? I assume the headers should be the same, but not sure if the piping will fit. In case you are wondering why I would do that, my buddy is getting rid of his for 8 spd and will sell them to me cheap. Thanks.:naughty:
Kdog57
