Loose Climate Control Knob
WV34
2012 Outdoorsman Quad Cab
The fan speed control knob in my 2012 Outdoorsman has a bit of play in it, as if it isnt screwed tight or something. I can wiggle it left, right, up or down a slight bit while all other knobs are super tight with no play.
Does anyone know if this is because it may have been bumped pretty hard that created some give or if there is a way to take apart and tighten something within the knob?????
Any help would be appreciated, this is a very small and picky problem but I have really found this to be annoying as of late :suicide:
reindeerman
Knoxville, TN
2011 & 2002
I purchased my 4th gen 2011 model about 18 months ago. I noticed the same thing you are talking about and figured it would require an new AC/heat control switch module. The after using it for a year or so I got over the looseness of the fan speed switch. If works fine and I haven't looked back.
fastbike02
GB
mines loose as well, I just figured it was a design flaw
