Low coolant light on on CTD
JRS950
All over the great USA
Cummins 6.7L
Okay, I've got a 2018 Ram 3500 CTD. The low coolant sensor has taken a dump. The dealer says they have to replace the entire overflow tank to correct this issue. $500. Anybody have a more economical solution. The coolant level is correct.
Thanks in advance for your help.
JRS950
JRS950
Cummins 6.7L
mtnrider
Georgia
If you are able to do the work yourself it's not too bad. You'll need to pull the passenger battery and in fender well liner to get in there but it's not too difficult.
Cummins diesel
Kentucky
2015 Longhorn
Cummins
Did you ever get it figured out? I got a 2015 Ram 3500 HO that just started doing the same thing. Coolant is full but low coolant light is on.
dputnam01
Escondido, CA
6.7L Turbo Diesel
I heard that the issue is that it is an optical sensor, and the coolant reserve tank gets so stained that the sensor can't pick up the coolant level? My coolant light just came on at 49k miles, but the level is fine. I was looking at various YouTubes and they say that changing the sensor is a waste of time. The new tank comes with the sensor. They also stated that the coolant tank change out was quoted at $500 by dealer. I'm still going to check it out further.
dputnam01
Escondido, CA
6.7L Turbo Diesel
Well, I was wrong. The sensor picks up the magnet on the coolant float. Either the sensor has gone bad, or the float is "stuck". Sensor can be changed without draining the coolant.
Robert Mc
Fresno, CA
6.7L Cummins
All of my research shows that the majority of the time it is not the sensor. The OAT coolant creates so much sludge and staining and other, whatever, in the reservoir that the magnetic connection between the sensor and the float is blocked so the float returns to the “low coolant” position. Changing the sensor does nothing because the pathway is still blocked. There’s a YT video showing how to test your sensor with a magnet to see if it is still good. Buying an OEM reservoir comes with a new sensor.
I may try disconnecting the bottom hose on the reservoir, draining it, and blasting the inside of the reservoir clean with a low pressure pressure washer and letting all of the debris wash out the bottom and seeing if that fixes it before I give RAM any more money for their incompetence.
My 2018 RAM 2500 with 144K miles just experienced the low coolant issue like everyone else’s trucks will eventually. This is just another piece of junk part in a long list of junk parts RAM is putting in their trucks and it’s really aggravating.
Add this to their airbag module under the center seat, the 68RFE valve body, and some of the other junk parts they use.
