Lower glove box light
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
Hi guys,newbie to the site and love all the info.
From doing a little bit of searching tonite and i think I found my answer(unless I missed it here somewhere..possible but I tried 1st before I'm asking here)to the lower glove box light on my 2010 1500 laramie crew cab 4x4 not being there.(bought used a couple weeks ago)
I understand you can get the upper light set-up for models that don't have a light up top to install(like an express)if there are wires there to plug into.
My questions are.....1)is there a light set-up that can purchased for the lower box?
2)can the same pigtail light set-up in the upper box(i have that)be spliced into with another same set-up and put in the lower?
3)is there a forum link to do this if I missed it?
Wife opened the box tonite and was pitch black and I thought..."well that's just stupid".it was late so I'll check in the morning if I have a bulb in there.
But for now I'm under the impression nothing is there and these were my initial thoughts on sumthing to do to get sum light in there.
I don't want to just Jerry rig something up to get some light ,kinda want the factory look.
Sorry for such a long post but the more you guys know the easier for an answer right?
Any help or thoughts on the matter would be appreciated.thanks.
Hardracer
Hardracer
Swfl
Well I finally found my answer from a previous posting....it was a newbie miss alright.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
So what did you find ? Your answer may help someone else :)
MCMLXIX
Las Vegas
5.7 HEMI R/T
So what was the answer to having a light in the Lower Glove Box ?
Factory option or have to make your own?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
On my 2015 there is a little knock out for access for the factory harness ! Buy a OEM Glove box light kit ! and it was plug and play. I also had factory wiring harness for the under hood light, BUT they stopped adding them later on . DO NOT know what years they stopped.
Open your glove box and lok to see if you have 2 knockouts. Front one for the light push button and side one for the light to come out !
Hope this helps a little
