Lug nuts
Cfire116
Cary IL
Howdy all,
So I was looking to replace my factory lug nuts and get ones that did not have that crappy chrome cap and were one piece. I was looking and the ones I found said that they did not work on factory rims. I was wondering why and if anyone had a suggestion for some that would work with factory rims. I wanted to get black ones.(yes I know that they will scratch over time) my truck is a 2012 ram 1500 sport.
Thank you
BOWERSFJ
Uniontown OH
Summit Racing ... Gorilla
daveray9
I had black. They arent available, but they arent worth it. After taking them off once they scratch and rust.
Venum wheel accessories 2012-2019 Ram 1500 Black OEM Factory Style Black Lug Nuts M14x1.5 W/ 22MM Hex Close End 1.5" Tall 5x5.5 New Model Ram 1500 Made in USA https://www.amazon.com/dp/B01H6KBP4Q/ref=cm_sw_r_cp_apa_i_-8nTDbRVCCY00
daveray9
Actually they are, just a new link.
Venum wheel accessories 12-19 Ram Truck 1500 Black OEM Factory Style Black Lug Nuts M14x1.5 W/ 22MM Hex Close End 1.5" Tall 5x5.5 New Model Ram 1500 Made in USA (LNRAM141BK-20) https://www.amazon.com/dp/B07GDZ9F7Q/ref=cm_sw_r_cp_apa_i_Q-nTDbF3A2HRJ
cityboy21
NW Indiana
Had Wildpeaks installed on my truck last week and Discount Tires brought the lug nut issue to my attention. Didn't know the factory ones have an issue of swelling and possibly having the caps strip on the lugs making them difficult to remove at some point. They showed me how the lug socket barely fit the stock lugs on my truck. Bought a set of Gorilla's off of Ebay that were around $25 for 20 lugs. I really don't expect them to last too long before rusting but we'll see. Might have to go the stainless steel route to eliminate the rusting issue. Gorilla does have a set that has a lifetime warranty that I'm pretty sure pertains to rusting. Need to look into it further but for $25, I just went with what will probably be a temporary fix for now as I wanted the stock ones off the truck ASAP to avoid any issues with not being able to remove them. Be proactive and end the swelling nuts issue. LOL
https://www.ebay.com/itm/20pc-Goril...uts-14mm-x-1-50-Thread-Set-of-20/273885647073
88ROOK
illinois
just get the mcgards and be done with it, might be a little more expensive but well worth it
daveray9
Black?? I got their black locking ones and they have held up great.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I've had these Venum lugs on my truck since oct 17 and no issues with rust. Still look good, but I AM in socal, so.......
Wayne E
Winnipeg, Manitoba, Canada
I have same on my 2018. Rotated my tires twice, and no scratches or rust. And they have been in some deep snow. Just make sure the lugs you order work with factory rims. They are a little wider at the base. The other lugs are for slimmer for aftermarket rims.
