Moisture in Bed Camera Assembly
smcguire36
Fulltime RVer
Cummins 6.7L HO
My center break light / bed camera assembly has gotten moisture in it and the camera is totally obscured. Is there a way to open the assembly to dry it out? I removed the screws and took the assembly off the truck but didn’t see any way of opening it up.
This is the assembly that is mounted directly over the rear window of the cab on my 2019 Ram 3500 Laramie DRW. I use that camera every time I hook up my fifth wheel trailer which is quite often as my wife and I are full time RVers.
jws123
nj
Your in the 3rd gen section Not sure exactly what the piece you are talking about looks like because mines a 2011 but like anything else probably cant take it apart. However if there is moisture in a electronic device put it in a bag of rice for 24 hrs try to dry it out or maybe let it sit in the sun?
geneseedennis
