Mopar 2" Lift P5155797 for DS trucks $100 in Spokane
Status
Not open for further replies.
kurek
Northwest
What's for sale:
A Mopar 2" lift, part number P5155797 - minus the front struts. This is everything other than the two front Bilsteins.
This is two rear lift springs, two rear bumpstop extension brackets, two rear sway bar/brake extension brackets, two rear Bilstein shock absorbers, the necessary nuts & bolts and the official instructions to install it.
This does NOT include the two front shocks. It is everything else other than the front shocks.
If you want to complete the Mopar lift kit you need two of Bilstein 24-187367 which are currently about $300/pr new.
No rust. See photos. There is no oil on the shock bodies, the rubber is not dryrotted and there is no evidence of wear or deterioration in their function. I removed it because I wanted my truck lower again.
This will lift the back of a quad cab or crew cab 2wd or 4wd Ram DS 1500 about 2 inches. If you have a RCSB it will be almost 3 inches because they are lighter. This only fits 4th generation Ram 1500's. That means 2009-present with 5 lug wheels.
This also extends rear suspension travel by about 10% over stock.
I am located in Spokane, WA.
I'm asking $100. That is either a deal to you or it's not but it's the amount of money I'll take, these can sit on a shelf until someone agrees that's a deal.
Again this is every part of the kit other than the 2 front Bilsteins, so for about $400 total you could have the Mopar P5155797 which is $1166 on Amazon right now
See photos.
rule18
Admin
NY
2017 Rebel
Please re-post one of your pics with the required handwritten sign, thanks.
rule18
Admin
NY
2017 Rebel
Thanks for the quick action. GLWS.
JB Weld
WI
Any idea how much to ship to 54449?
kurek
kurek
Northwest
This has sold, sorry I don't know how to remove it.
Status
