Mufflex Resonance Cancellation Pipe Kit !!!
BSMExhaust
Coming 3/11/13 is the new Mufflex Resonance Cancellation Pipe Kit.
PreOrder Here
Mufflex Resonance Cancellation Kit fits 2009 to Present Dodge Ram 1500 Mufflex 4.7 & 5.7 Hemi Muffler /Exhaust. This is a do it yourself kit for the 2009 to Present Dodge 1500 4.7 & 5.7 Hemi truck made from 409 stainless steel. This resonance cancellation pipe does not effect exhaust flow, sound or power just eliminates in cab resonance. Installation will require a small section of factory pipe being removed before your Mufflex Retrofit Kit. Installs in approx. 45 min with typical tools you have at home.
This design works using the Helmholtz Resonance System.
Helmholtz resonance finds application in internal combustion engines (see airbox), subwoofers and acoustics. Intake systems have been described as 'Helmholtz Systems' have been used in the Chrysler V10 engine built for both the Dodge Viper and the Ram pickup truck, and several of the Buell tube-frame series of motorcycles.​
Chewy
Bettendorf IA
V8
Hahaha... Funny, I posted this idea up a couple of months ago! So this will fit inline with my mufflex14 setup?
Sent from my miniaturizer via tap dancing...
B
BSMExhaust
Yes, you will need to cut a small section of the factory pipe out just before the Mufflex.
SILVER_BULLET
So im a little confused anyone care to explain what this does and how it works?
WhiteExpress
Midland, TX
It allows sound waves (the annoying standing waves that cause resonance) to travel up into the tube, which is capped off. Basically, the hope is that it will cancel out the annoying drone by reflecting and absorbing standing waves.
WhiteExpress
Midland, TX
I wonder how it would work with the muffler delete and no resonators.
Only one way to find out! :-D
05Fourwheel
