RAM 2009-2018 1500 Aggressor cutout pipe kit at Got Exhaust
APPLICATION 2009-2018 RAM 1500 Aggressor cutout pipe kit
DESCRIPTION The Aggressor is an electric cutout pipe kit that is vehicle specific. We designed each application for the best clearance, sound and power. There's no need to figure out your install location, all of the guess work has been done for you. Most kits eliminate the need for any welding at all. Go from factory quiet to Aggressor riot! Simply bolt in and unleash hell. All systems are stainless steel and proudly made in the USA.
KIT CONTENTS • Aggressor Cutout Pipe Kit
• QTEC electronic cutout valve
• Wiring harness
• Dual position momentary switch
• Hardware & Gasket
• Instruction sheet
With a touch of a button make your RAM go from mild to WILD!!!
You can find this on our site here
https://gotexhaust.com/i-23720303-qtp-2009-2018-ram-1500-aggressor-cutout-pipe-kit.html
Then use promo code MILDTOWILD for your discount!
• Wiring harness
• Hardware & Gasket
• Instruction sheet
