Robslaw1969
- May 23, 2024
- 1
- 0
- Location
- NJ
- 2017
- 3.6L V6 automatic transmission
Good morning. can someone please help me? I believe I might have a leak in my transmission fluid case. However, every time i try to look up how to diagnosis and change it, i cannot find my transmission case in any of the diagrams. For example, all the videos show the fill plug above the plastic pan on the driver side with a yellow sticker below it to show where it is. That is not mine. Mine is on the passenger side, and has zero obstructions to get to? how often do you need to change the fluid? Its been running hot, about 190-195 degrees when driving in 90 degree weather. I've had no issues with gears changing. i noticed my trans pan was covered in a black oil like substance, but no my oil pan is not leaking. Oil level has been constant in engine.
I'll add its a 2017 1500 Laramie, full size cap; short bed. 3.6L engine v6 (the E85/gas model) never used E85. Automatic transmission; assume 6 speed not 8 speed.
Thx for any help you can provide.
