The ad for the new 2022 Jeep Wagoneer has a 6.4 with significantly more power 471 hp and 455 pounds of torque. Could it be in the Ram’s as well?
Thats because the new jeep will probably be using the SRT 6.4l CAR engine. Not the 6.4l BGE for the Truck.
That's true, and I actually want the SRT version; more power, and I'm not trying to work it as hard as the 2500 where BGE is obviously the better choice.
If they can put the 5.7 in the 1500, which is also a car engine, they can give us the SRT too. I'm a little miffed at this point, every other truck now is more powerful than our 1500's. Even the pathetic Nissan.
FYI... the 5.7 in the 1500 is also different from the 5.7l in the car
the block might be the same. But interals, cam profiles, materials are different.
Apparently they build the 6.4L truck engines for duty usage and not just occasional
tire burning starts like the 392 Charger/Challenger/Jeep motors.
I'll give up some dyno #s for longevity any day...
I think if you change oil every 5000 miles or so with any quality 0w40 synthetic oil they should live a long timeYou can google the 6.4 and find all sorts of interesting things. Not sure how many variants are made now, but I know our Ram Truck variant gets a forged steel crankshaft (who does THAT anymore?!), sodium-filled valves (!), and other goodies I forget. This thing could go forever if not for lousy lifter / cam lubrication. Maybe by using Red Line Engine Oil it still can?
I tow and haul whatever I want, as often as I want, with absolute confidence with this truck.
I will take my chances. I will change every 5000 miles or so using PuP and not a bit worried about it.not the case - look at the "synthetic oil" or "hemi valve tick" threads.
