I just received this back from FOX. Took them a few business days to respond lol.
The 88306073 w DSC adjusters / 88302073 are built to BDS specifications for their 6 inch lift kit. Only available for their 6 inch lift.
They will maintain the ride height at 6 inches.
If a preload adjustment is necessary for your application DO NOT adjust preload with the coil-over on the vehicle.
Remove the coil-over from the vehicle and use a spring compressor to remove the spring hardware and spring.
Once the spring is removed, you can adjust the preload ring. DO NOT Exceed more the 1/2" of additional preload.
½” additional preload will increase ride height approximately 1.00 inch.
