- Joined
- Jan 17, 2016
- Posts
- 23,962
- Reaction score
- 55,300
- Ram Year
- 14 Sport
- Engine
- 5.7
Gen3 Hemi Racing
Trent Steeves · 18h ·
+2
While the rest of the team has been hard at numerous other items/products along with PRI Show preparations, Brian Smith has been keeping the light on, going after a whole host of things in Texas....and this is one of the most needed and exciting things we have worked on together. I know, hard to say it's cooler than the awesome billet head, but...this is something that will help far, far more people affordably and effectively make their G3 Hemi dreams come true.
A longstanding difficulty in modifying the G3 Hemi and installing racing camshafts has been the lack of a high performance timing set.
Ideally we needed a timing set for the VVT style engines that eliminated the unneeded phaser in such racing / swap use and allowed for the precise positioning of the camshaft to crank, often desired to optimize horsepower and torque.
We are pleased to offer a new solution to the market that not only addresses or eliminates those concerns, it also offers significant improvement, is built on high durability proven components/design and does so below the cost of far more limited and inferior timing set solutions currently used.
The steel billet upper and lower sprocket with hardened teeth drive an OEM style, highly durable low to no stretch chain. The upper sprocket eliminates the unneeded and heavy phaser and incorporates the cam sensor window ring in parent material, as part of the sprocket, eliminating the sometimes troublesome attachments that allow movement or can be the source of failures. The lower sprocket has 9 keyways, center and four, degree by degree, plus and four minus to support precise degreeing of the camshaft.
The full kit includes sprockets, chain, thrust bearing, tensioner, cam bolt and washer and is offered at $549. The partial kit includes lower multi degree sprocket and phaser tool with lock or limiter for those that want to utilize their upper sprocket and phaser for only $129. For those that just want the multi keyway lower sprocket, it’s just $99.
We will soon be taking orders for these items, and with final validation complete, we plan to begin customer shipments in Feburary.
Come see it and us in booth #3126 at the Performance Racing Industry Show.
+2
Blackbird Performance
18h ·While the rest of the team has been hard at numerous other items/products along with PRI Show preparations, Brian Smith has been keeping the light on, going after a whole host of things in Texas....and this is one of the most needed and exciting things we have worked on together. I know, hard to say it's cooler than the awesome billet head, but...this is something that will help far, far more people affordably and effectively make their G3 Hemi dreams come true.
