No airflow in the cabin
Snivelo3500
2017 3500 Tradesman, not sure when it stopped working but I can’t get any airflow. A/C, heat, vent, floor, defrost, no settings allow airflow but I can hear the blower when I turn it up all the way. Any suggestions?
KoboldTaco
Los Angeles
Cummins 6.7L
This old thread might help out a bit to identify what blend door might be causing you frustration. I’d also open the blower motor area and make sure you are truly moving the blower assembly and there are no immediate blockages right there.
pull the lower glove compartment
check your Cabin Air Filter
look to the left of the blower motor, you will see a electric motor, that is an Actuator.
When you move the HVAC Controls, you should see that actuator move, watch the white plastic piece
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
I had my recirc door fall out and it was laying on top of the blower causing the same symptoms.Pull your blower out and take a peek.Good luck and welcome.
JustinRam1500
