MarcoFuc
I've been having a issue with my heat on driver side, and other threads I've found or read isn't the same as mine almost similar but not really. So when I have the air on cold I have full strong air flow on driver side, the moment I switch to heat the air is really low flowing out and barely Luke warm coming out, but strong as it can be with heat and air flow on the passenger side I do have a dual climate system in my truck and it's a 2013 ram 1500 sport any suggestions I'm open for! I've done heater fore flush, I've tried seeing if I had air bubbles, I've also checked the return hose and hose going into the heater core both only have a 1 temperature difference between the both. So I'm lost with whats going on.
