No brake lights without key?
ckeefer58
So this may be a stupid question, but do the brake lights on a 4th gen come on when the key is off?? Just noticed on my truck that no key, no lights.
Sent from my Nexus 6P using Tapatalk
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Kind of confusing, but what do you mean? The key is ON (running or just in the on position) with lights on or just turning them on without the key?
ckeefer58
ckeefer58
If I step on the brake pedal with no key in the ignition, I don't have any brake lights. With the key in acc or on, they work as normal.
ckeefer58
ckeefer58
Hazards and parking lights working fine as well.
perk7089
Cummins 6.7
Yes mine is the same way! They're designed to work that way
SilverStreak88
Houston, Texas
5.7 Eco Gasser
That's weird, never seen that. My brake pedal/lights are always "hot" (meaning they come on when I step on it. Anybody else with a 4th gen you know that has that issue?
ckeefer58
ckeefer58
I know the newer GM trucks work like this, wasn't sure about the RAMs. I was changing bulbs and went to test them and I had no light! I guess I just never noticed it before.
ckeefer58
ckeefer58
What year is your truck btw?
perk7089
Cummins 6.7
2010
Sent from my XT1080 using Tapatalk
ckeefer58
ckeefer58
I wonder if it's only 2010s then. I always thought they worked with or without the key.
BigDogg795
Ronkonkoma, NY
My 2014 will light up regardless of the key being inserted or the truck being on.
Rzrman328
The treeline
Mine won't come on without key.
I thought it was weird too....only found out recently when I did my 3rd brake mod.
perk7089
Cummins 6.7
Not sure.. the older vehicles did
ckeefer58
ckeefer58
Apparently it's only the 09-12s then.
