No Headlights only high beams
Kwolesla
Pennsylvania
The headlights on my 04 2500 don’t turn on. Fog lights and high beams work fine. I replaced the multifunction switch and that was not the issue. Anyone else have this issue? Any thoughts on what to try next?
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
How do you know it's not just the low beam filaments burned out? Low beams, most of the time, are the first to burn out since they're used the most.
markabby
Monticello, Kentucky
2020 Limited
LED's ?
HarryS
Air Force
Clovis NM
Don't just throw parts at it. Get a wire diagram and find out where the voltage stops. Could be fuse, relay etc.
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
The high beam , fog and low bear are on separate fuses low beam has a fuse high beam has a fuse and fogs have a fuse ! So that being said check or change the fuse ! That is where i would be looking! first before throwing money at it!
chri5k
USA
Diesel
Aren't High Beams headlights?
Raadz
