No power to F28 Fuse
Ramman70
Coshocton, Ohio
I don’t have power coming to my F28 Fuse in the exterior fuse box. I sent my Tipm to FoxUp and they said it was fixed. I paid Big Money to get it fixed. They sent it back and it didn’t work. I have let them know but to avail. Never use them again. Can anyone steer me in the right place on how to fix this? Thank you very much’!
Michaelhb439
Enfield,ct
3.6 l
Check the power distribution center underneath the fuse box. U may have some corrosion on one of the 4 modules. I just had an issue like this and had to re wire and add connectors to the damaged wires. Each module has a color. Blue, green,black and grey. U have to check them where the wires are pushed into and check for corrosion. If u find a cavity filled with corrosion u need to pull out the connection and re wire it with a new connector .
This diagram is the modules that plug into the bottom of ur fuse box.
