New to me 2013 with issues... Help
trucky
Ohio
Hello all, I had a 2005 Dakota and a 2013 F150, but yesterday I got a 2013 RAM slt 5.7 for a good price and under 150k miles. Already noticing some issues and don't know where to start.
The main thing is there is a 4x4 service light on the dash... That one was obvious and the dealer reduced the price for me, stating they did a diagnostic and maybe some looking around but don't know what's causing it. Research says anything from a fuse, to bad tipm, to transfer case issues but before I spend money on a mechanic I wanted to see if this was a common problem and/or an easy fix?
The other thing is pretty random, the cigarette lighter in the center console has no power. Again... I can check fuses and maybe the wiring but beyond that I don't know if this is common for the Ram or something that needs a shop to fix. I need it for charger, dash cam, etc. I haven't checked the "household" style outlet so hopefully that works.
Thanks for any info and I look forwarded to learning more about these trucks!
NETim
Nebraska
5.7L
Always a good thing to do on these trucks is ensure all of the fuses are fully seated in the TIPM.
Get a code reader on that thing and see what codes come up.
David H
USA RET
Minneapolis
No doubt what Tim said about seating all the fuses. Looks like your console cig lighter is F104. Here is a helpful interactive site for these trucks. https://www.startmycar.com/us/ram/1500/info/fusebox/2013
As for the 4WD light, it's common to have a bad/corroded connector at the transfer case motor or a failed motor.
It's also common to have a slightly weak battery. This will cause all kinds of electrical havoc.
Daw14
South Florida
The forums search feature has lots of useful info, with plenty of members personal experiences.
Bob Templeman
