No power to radio and back up cam
roket77
When I went to start truck, it acted as if battery was dead. Had dealer replace it prior month. The gauges and other dash stuff were acting crazy... It didnt start for about 15 minutes. After it started,,there was no power to radio/screen. No back up cam. Check engine light was on and dealer did quick test,,,they said,,something had low voltage(generic answer). Could a relay or fuse for the display be blown from what happened with starting issue? I'm taking to dealer Dec. 2(warranty), but would love to see if the fuse/relay could be the problem. If so, where is it located? I looked at a diagram but couldnt locate anything for the display. Thanks in advance.
Mark
dterrel
