hunterdan
- Joined
- May 7, 2018
- Posts
- 1,199
- Reaction score
- 1,588
- Location
- SE PA
- Ram Year
- 2019 classic
- Engine
- 5.7 Hemi
The MAP sensor is in the back of the manifold, so...More of an issue with GDI engines that don't inject PEA-treated gas at the intake valve stem. Add a turbo, and you gotta clean the compressor blades too, from the PCV gouk misting on it.
CRC Intake Valve Cleaner is a good one for this - if you want to clean your piston crown you could try it. Just be sure to spray in AFTER the MAP sensor!!!
