Noise problem
SgtSloane74
Ingleside, NY
Hemi V8
Hi ya'll I have a 2016 Ram Hemi Big Horn. Where do I begin. I guest the most recent problem is the squeaking from my dash. It just started getting cold here and this morning when I started driving, I noticed all the noise. Not sure if its because of the cold but its annoying. Turn the music up. Anyway, I was wondering if this is a failure with something in the clips or washers or what. Thanks.
tron67j
Maryland
Just happens, plastic on plastic and metal can cause squeaks. You kind of just have to keep removing things to see if you find the area of issue. You can look online at different ways to minimize the sound such as adding material between the offending parts.
First try the easy things like putting pressure on areas while driving. You may at least locate the area of concern. You can also pop off many pieces like radio bezel, trim under steering wheel, glove box and trim, etc. to see if that stops the sound.
Good luck.
