Odd slosh in 2500 cabin…
NikNak
MidSouth = TN
My 2500 sits a little & I drive 1500 more often. The last couple of weeks I heard a sloshing of water noise & then a hissing of what sounded like water dropping on hot pipes & a little water evidence on the passenger floorboard. Has anyone else experienced this? Is it a plugged drain hole somewhere from the spring pollen/airborne seeds?
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
probably coming in from the 3rd brake light. Check under the rear seat and in the floor storage compartments for standing water.
You can snag a replacement gasket off amazon for like $10.
NikNak
NikNak
MidSouth = TN
It’s definitely in the dash…. very far removed from the rear third brakelight.
NikNak
NikNak
MidSouth = TN
Yeah… it was the plugged cowl drain holes. I watched a youtube vid, lifted the cowl filtration piece & proceeded to scratch the chit out of my arm as I reached in deep enough to clear the drains. I guess this will be an annual thing as we live under trees.
Tulecreeper
AZ - 83 Miles SW of the Geographical Center
Wait until you're in your 50s. If you spend a lot of time in the sun you will develop Actinic Pupura, and that scratch will be a giant purple splotch within 60 seconds and stay there for 2 weeks.
southalum
