oil catch can?
jdeere05
Indiana
Ok what are they? what's the purpose? where do you get them? and how much $? And do they void warranty? ..I've been hearing people talk about them so curious now. Thx guys
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
A catch can stops oil from being vented back into the engine, via the throttle body.
From the factory a hose vents pressure from the crank case to the TB, along with the pressure it vents, it also pushes a small amount of oil through the tube which is then fed back into the engine. This is not good for your truck because it lowers your octane level.
The catch can is placed in the way and the oil falls to the bottom of the catch can and the pressure is released back into the engine, minus the oil.
This is definitely the first mod any hemi owner should do!! It will add to performance but not like you think. You not going to feel anything on the "butt dyno" after you put it on, but it will definitely stop your octane rating from dropping, so it is a must have if you are going to add a tuner.
Also, it will not void any warranty on your truck....period!
You can get them from Moe's Performance: Link added - Billet Technology Catch Can 2009-2013 Dodge Ram 1500/2500/3500 5.7L Hemi
