Opening Console
KennyG
Hi All -
Just picked up a new 2013 Ram Laramie with 8 speed tranny.
Shifter on the dash, not in the console.
Am trying to outfit it for my computers, phone, flashlight chargers, etc.
Can't figure out how to pull the bins out of the center console / armrest.
I want to run some wiring thru there for chargers, etc.
How can I access the interior of the console?
Thanks
Kenny G
WhiteExpress
Midland, TX
Not entirely sure what you mean.
You want to open them up, as in remove them from the truck to drill access holes etc?
Corbin
Chrome trim ring has to be pryed up out with trim stick tool or strong fingers, then remove rubber piece from pocket at front of console, you should find 2 Phillips screws, then, with armrest open/out of way, pull up the surrounding trim piece around cup holder area. To go further and remove cup holders/bin, you need to remove rubber pieces from cup holders and bin area, to gain access to screws then disconnect plug from 12v socket then remove cup holder/bin. This should gain enough access to run wires to bin under armrest.
joshhhh
