p/s cold start howl
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
what is the deal with this noise?truck sits over night,below 30 the next day,only first start p/s howls for about 5 sec. or so.i keep hearing that this is normal.above freezing outside and no noise.
emjohn4
Flush and replace the PS fluid with synthetic. Redline PS Fluid cured my PS growl on my Neon.
Try ATF+4 or Redline, should go away. You may need to flush it twice.
Karlsweg
SW Florida
Are you sure it isn’t it’s the clutch fan? Mine sounds like a jet engine for a few.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
No clutch fan here, she still lets you you know it’s cold. There are worse things to lose sleep over.
emjohn4
FWIW - attached is the TSB for the cold start PS noise (different car, but still Chrysler product).
  • TSB 19-03-98.pdf
S
srv1
blasdell n.y
i have heard that possibly the noise is coming from a bad o ring on the return line going into the rack.i have no fluid leak but i heard this bad o ring can be drawing in air until it seats after a few sec..i am going to ck. it out tommorrow.does this sound possible and has anyone else experienced this problem?
S
srv1
blasdell n.y
UPDATE! noise gone.was sucking air on low sd.p/s.replaced low sd.rack to cooler and cooler to res. lines.it was either bad seal from old hard hose or o ring at rack.hope this will help someone having this problem.
Orca
