P0299 troubleshooting.
Jberry805
California
I have a 2014 2500 6 7 I have code p0299 active.
Can anyone help me getting troubleshooting steps for this?
MADDOG
Living in a Firepit
6.4L HEMI
It's a turbo under boost code. There are quite a few potential causes such as:
  1. Turbo or supercharger replacement.
  2. Repairing of the intake system.
  3. EGR replacement.
  4. Boost pressure sensor replacement.
  5. Low engine oil pressure repair.
I'd start by measuring the boost pressure & cleaning the EGR. Make sure your oil pressure is within design operating range.
If boost is normal, then consider changing the sensor.
If boost is not normal i.e., low then there could be a boost leak in the piping or a mechanical issue with the turbo or actuator.
J
Jberry805
California
  3. EGR replacement.
What should the boost pressure be at idle , acceleration, and cruising?
