P0501
Njacobson
Canada
2012 Dodge Ram 2500 Cummins g56 . Speedo dead with lightning bolt and traction control lights on . There is no sensor in diff and transmission, replaced both rear abs sensors and shows code p0501….please help. I also replaced tipm with no luck
Rlaf75
East Hartford CT
2021 Bighorn
Does the scan tool you used to pull the code have live ABS data capabilities? A good scan tool should be able to show live wheel speed sensor data. If yours does then plug in and bring it up and see if there is communication with all the speed sensors. If there's no communication then there's more than likely a computer or module issue
