P0601
jcurryii
Somerville, Al.
Had pcm rebuilt. Failed after 2nd restart. Company said I had a battery issue. New battery disconnected for a time before putting unit back on. Started fine 4 times. Charged battery for several hours. They have since removed the code again under warranty. Battery is fully charged and unit should be back tomorrow . My question is, will every time there is a battery problem will I get the P0601 code back?
datammwv
Parkersburg WV
2018 & 2017 2500
Did the replacement pcm fix you problem?
Sent from my SM-G975U using Tapatalk
joshhhh
