bouf0010
- Jun 3, 2013
- 430
- 89
- 2013
- 5.7 Hemi
if youre gonna do it, make sure you get it with mandrel bends - not that crush bent stuff.
Sent from my SGH-I317M using Tapatalk
So if i don't do any mandrel bending and just swap out the stock Y pipe for the magna flow, would it really be worth my time at all?
^Dyno proof? Given the cost of custom exhaust work around here, I determined the Y-pipe wasn't worth it for me. In the end, it's all flowing down into one 3" pipe.
Lol thats totally illogical. If the biggest restriction in the factory exhaust after the cats is the y whether it flows into a single 3 or 2x 2 1/4 is not important, the restriction is still there...
This was taken from Flowmasters website. I have also seen this on other sites as well. I was also told this from the shop that installed my set up.
12. What size exhaust tubing should I use for my street application?
The size of tubing used in an exhaust system is as important as selecting the right muffler. Your tubing diameter choice will affect the sound level and performance characteristics of the muffler, but keep in mind that bigger is not always better. Using tubing that is too large can actually hinder exhaust scavenging by slowing the velocity of exhaust pulses in the tubing. As a rule, most stock street applications (dual exhaust) use 2.00” through
2.25” tubing, and modified street applications will generally use 2.25” or 2.50” tubing. Very rarely will 3.00” tubing be used for street applications.
^^ With your intake and maggy they will all work well together with the new Y pipe to help improve performance. Not a whole lot but it will give you some improvement in performance. You have to figure with your intake you are pulling in more air...with the new Y pipe there will be less of a restriction of air flow going out.
In theory yes, but it would be so minuet that it wouldn't be worth the cost. With a blower and no cats... yes a bit. Not as much as you'd like to believe. Looks impressive on a forum sig mod list.
Lets see.... $200 + for 391 hp vs 390 hp???
Immeasurable phantom gain for the cost... what ever helps you sleep at night.
