Pics wanted - leveled with 35s
HKkid
HKkid
Missouri
yes bilstien 5100's on max lift setting
Then with proper backspacing you should be fine. With stock 20s you are going to rub, get something with a little bit of bs, or get wheel spacers. You keep saying different suspension, and you're right. But just because we have different suspension doesn't mean you can't run 35s.
nim81
Fredericktown, MO
5.7L
well im running stock 17" rims with 1.5" spacers. it doesnt rub bad now . just barely when im at full turn in reverse.
i might go the 35" route when these summits wear out. and if i do ill be getting aftermarket 17's
hemi powered
Taylor, MI
HEMI
Ok so If I get 20 inch kmc rockstars can I run a 35 inch duratrac on my 08 4x4 hemi quadcab with leveling kit?
quietpeen
2021 TRX
Hellcat
I'd say no, but thats just my opinion.
I agree with this.....with how far the wheel and tire stick out you will most likely rub the fender when turning
