Please help me! Tire help!
Ifish1002
Ok I’ve been getting so many different Responses maybe I can get a better answer here.. I had just recently installed a Fox 2.0 coilover kit to get my truck leveled..now I’m looking for tires on my stock rims which are 20x9..the size tires I want are 35 x 12.5 x 20 in the Toyo open country MT, now will these work for me? I’ve had responses that said you need spacers then some said you do t need them and that the only time they would rub is at full lock
Triumphx
What offset are the wheels? I run 35x11.50 on 0 offset 20x9 with bils at 2.8” and barely don’t rub
6.7CumminsDrvr
The Dude abides………
Georgia
Those Toyos will need a spacer. I run 35’s on stock 20x9’s but per the manufacture specs, them Toyo MT’s are a bit wider than my MasterCraft Courser MXT’s (and they JUST barely fit without contacting the knuckle).
Puba08
Long Island
Probably gonna rub without spacers.
ThunderMug95
North Prince George, VA
My tires rub slightly, they are 12.5 wide and 33.2 diameter on 20x9 +18 offset. I think the stock rims are +19 maybe?The sidewall treads are what touch on mine and if I recall your tires are side-lugged as well.
jaccard30
