Please help stalls out, rough idle, wont stay running.
melmom
Amarillo, Texas
We have 95 dodge ram 1500 5.9L. We have replace the throttle body postion sensor, air intake sensor, pvc valve, MAP sensor, checked the o2 sensors and the cat they are fine. Replaced fuses, reset ecm with every replaced part, I've google and youtubed everything about this truck and it still won't stay started. Stalls out, we ran seafoam through throttle body. Please help
EvilSpirit
5.9 Magnum
Did you try cleaning the IAM (Idle Air Motor)? It is on the throttle body and controls an air bleed circuit to set the idle.
southalum
