Power inverter
Lawrencec346
Tennessee
Installed a power inverter plug in the dash of 2013 ram 1500 using the factory plug and replaced the fuse but it still doesn’t
work what have I not done or does it need to be programmed
MADDOG
Living in a Firepit
6.4L HEMI
So are you trying to power something without the key on and the engine running?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
In the quad cabs, i believe that the inverter is attached to the frame of the passenger seat, almost touching the seat cushion
I have seen them right above the transmission/driveshaft tunnel, under the middle seat or console
GeometryFletch
Arkansas
6.4L HEMI
Do have some pics of this project? That'll help part of it..
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I installed just the plug and plugged it in the factory plug that fit it that was behind the radio but no luck
Have to enable in ALPHAOBD and then also add a switch for it to work. I haven’t done it yet but probably will. There is another thread on it here.
geneseedennis
