ChrisGUGA
The install is going pretty well and I have the bilstein 5100s set at 2.8 and I'm trying to reinstall them on the truck. For the life of me, I can't get the 3 bolts on top of the strut into the 3 holes in the housing.
Is there some trick to this? I've tried installing and removing it 20 times and giving it a little twist to try and get it to line up properly with no luck.
Also, does it matter where the end of the spring coil is lined up? I read somewhere that they recommended having the end of the top spring coil facing outward.
Thanks a lot,
Chris
Thanks a lot,
Chris
