Projectors to reflectors Headlights
arsenault408
is it possible to switch out projector headlights for reflectors ?
brianw0048
EcoDiesel
I guess so but why would you want to go from projectors to halogen?
I just removed my halogen lights. If you want to swap that bad, I'll trade you.
Mr.AK902
Regina,SK
17'
The factory projector lights are still halogen, no loss there. I have factory projectors and will be swapping to the quad lights as well so I can do a better retro fit.
A
arsenault408
Is it just plug and play or do you need an adapter
brianw0048
EcoDiesel
I should have said projectors to reflectors...
I'm still confused though, wouldn't it be easier to upgrade the existing projector than a quad/dual? How does the projector housing limit a retrofit?
Personally...I don't like the quad retros, they look like the projectors are stuffed in and you're left with what to do with the high beam. I think the duals look better for a retrofit. Just personal preference.
@arsenault408 - If you have the projector housing, you'll need some sort of harness to run high/low beam quads. I'm pretty sure you'll need a harness if you do a quad retrofit as well.
OC455
Central NY
The Retrofit Source has a HID projector upgrade kit to replace OEM halogen projectors.
RHeller
usa
I have had oem projectors with HID's installed and quads retrofitted with morimoto projectors. I am more than happy with the oem projectors and HID. Not the cleanest line, but driving down the road at night, very little difference IMO on light output.
quietpeen
2021 TRX
Hellcat
I might be wrong but I don’t think you can go from projectors down to reflector like you want.
Jeremy from retroshop would be able to confirm that
