- Jan 17, 2016
- 23,853
- 54,912
- 14 Sport
- 5.7
I agree with alot of Sky's video's but i don't agree with his idea of the vvt tunnel totally blocking off the splash that hits the cam. Anytime the engine is running there's a pile of oil flung around inside the block,that's bore out by the fact a catch can will fill up,and if you look at how much higher the pcv system sits in comparision to the cam,there's got to be pile of oil flying around the crankcase,and some of that oil will be making it's way onto the lobe.Sure the cranksplash isn't maybe as much as we'd like,but it's still there.This is part of MMX's article,and they still say there's crank splash,and they're into the hemi more then pretty well any outfit,and way more then Sky ever has,as the hemi is all they specialize in.As a follow up, I found the video back from Sky where he refutes Uncle Tony and then very clearly states "the block did not change in 2009". A lot of great comments by him in the 5 mins following, and he basically sums up "it's my contention that this failure is due to improper hardening of cams/lifters, this is not a design/oiling flaw".
The END of the HEMI TICK?
The END of the HEMI TICK? As a former Chrysler technician I've worked on Hemi engines for over a decade and I've seen a lot of camshaft and lifter failures. ...youtu.be
In my opinion the root cause of failure is a two-part problem. Issue #1 is the design of the needle bearings of the lifter. The very early HEMI engines had large roller bearings (and a smaller axle) on their lifters. For some unknown reason, Chrysler went away from this design, and made the needle bearings much smaller, and the axle larger. These small bearings do not seem to take the load of being constantly activated and deactivated as well as the early design lifters. The second issue is lubrication. As I mentioned earlier, the only way the actual lifter bore in these engines receives any oil is when the MDS solenoid opens to deactivate the 4 cylinders worth of lifters. This means that during idle, and when the MDS is not active, the body of the G3 Hemi lifter receives NO OIL! (Mild caveat here, the lifter does receive some splash lube up from the crankshaft, but it is VERY minimal as the main oil galley blocks a very large portion of the potential splash lube. Combine this with the very high cam/crank centerline (7.464 Inches-compare that to a small block chevy at 4.521”) and the potential for the lifter to get any splash lube is near zero.
