Question on lowering
Bigboy0207
Fl
So I have a 2011 r/t with 26's on it. I want to close the gap in the wheel well. I was wondering how much I can lower it with out rubbing and losing my good ride. Even with the rims the truck rides great.
Any suggestions?
BlkRamRt
SoCal
HEMI 5.7
how much gap do you have now? you might only be able to do the 2 inch rear drop because if you lower the front you might rub with the big wheels
Bigboy0207
Bigboy0207
Fl
Measured today I have 3in in the front and 4 Inc in the front and 6 inch in the back I was thinking a 2/3?
TylerB
FL
what tire size are you using?
That's more important than the actual rim size. If the tires are close to the same height as stock then you'll be just fine with a 2/4 assuming the offset and width is close to stock as well.
blackout11
alpharetts GA
2011 R/T
Guy on here had 24's did a 2/3 and front rubbed like crazy 26 are huge for a drop
TylerB
FL
What size tires was that guy using though? If the tires are 33" tall or shorter it'll be fine assuming the offset and width is similar to stock.
joeg45
Katy, Tx
If you have a real low pro you should have no problem I had 295/30/24 on a 3/5 drop and still had about3/4-1" gap
Bigboy0207
Bigboy0207
Fl
Ok sorry for late response been so busy. So I wound up doing the 2/3. 5 no rub no bottom out. The front is a tad bit lower so from the side it looks like a little bit of a rake look but from the front or back totally even. Looks really good in my opinion with the rims. Any lower and I will have serious problems lol.
Bigboy0207
Bigboy0207
Fl
Thank of guys.. A little different but I like it
Rgesse
