Quick question
cincygoat
I am installing a hell bent steel leveling kit I have everything apart but I'm having issues getting the bolt out of the bottom of the strut I have the nut off I have beat on it to get it out and I have attempted to turn it out and I'm getting no where so my question is do I need to beat harder or is it threaded in
Terrence R
Try spraying lots of penetrating lube on the bolt and give it a tap with the hammer every hour, then spray more lube on there to get it to penitrate. Might have to leave it sit over night with the lube aswell.
C
cincygoat
I ended up cutting them out replaced the bushing with new moog bushing lifetime warranty grade 8 bolts from TSC and what dodge did not use plenty of anti seize not too bad
