Ram 1500 with 6 inch rough country lift squeaking/creaking sound when breaking and turning
dylan7338
Boulder Colorado
https://share.icloud.com/photos/005yfGexTtEc24v2sKa_QRdJQ
https://share.icloud.com/photos/0253hQOp6yFd_eG8zvOaSyLPQ
I have a 2022 Ram 1500 Big Horn on a 6 inch rough country coil over lift and 37x12.5s. It has had this same set up since 3k miles were on the truck and started to have this issue at around 12k miles. In the videos, you can notice a squeaking/creaking sound coming from the front end when turning the steering wheel and applying the brake. When driving, it feels like the noise is coming from either the upper control arms or breaks, however I have had my breaks inspected by multiple dealers as well as all four control arms replaced under warranty and the noise continues to happen. I notice that it happens more so when I am on and off of the break frequently such as maneuvering around a parking lot as well as when backing into spots. It sometimes occurs when standing still and turning the wheel but gets significantly more persistent when I lightly press the brake and turn the wheel at the same time. If anyone has any advice please let me know. Thank you.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Rough Country has the worst geometry in the industry. They will nickel and dime you the life of the truck once they start having issues. Unfortunately I see this everyday I’m not just hating
Gregf
