RAM 2500 Rebel Spec
Exdeus
2017 RAM 2500
Cummins
Hey Folks! Just looking to clarify a couple of points. The link to my window sticker is below.
I see that under optional equipment it lists a $500 credit for a customer preferred package 2GR. It has a few items listed below it as well, specifically Rebel Suspension. Does this mean it came with or without the rebel suspension? It has the blue colored shocks that you see on the PW on it. Also, does this truck include the factory lift that comes with the Rebel or does it not? Love the truck overall, but just wanting to clarify if anyone knows. It does have the gear selector knob like on the 1500's and not the standard lever shifter I have had on prior HD's.
Lastly, it also lists Tru-Lok front and rear axle lock. However, I only have a button for the rear locker.
2003F350
6.7 CTD
They were likely running a package discount to couple those and likely a few other options that were standard for the Rebel. If the trim level is Rebel (it is per your window sticker), then it's a Rebel and unless the factory components were replaced by either other options (unlikely) or aftermarket (that's a question you can answer), then it contains all the standard Rebel features/suspension.
As for Tru-Loc, it sounds to me like that's an LSD for the front? If it isn't then there must be another switch/button to lock the front axle as well.
joesstripclub
Kansas City, MO
2021 2500 PW
Generally the optional equipment section replaces the standard equipment. The credit section is something I haven't seen before, but I'm assuming that means you got a conventional front axle vs the standard front locker. Front lockers must have been hard to get so they knocked $500 off and made a special Rebel package.
E
Exdeus
2017 RAM 2500
Cummins
Thanks a ton! Yes, it's certainly a Rebel, I just wasn't sure if that was showing removal of certain items. The truck has the rear locker but not the front which is what I expected. Cheers!
